The window does not cut the external part of the wall
14 ANTWORTEN 14
Nachricht 1 von 15
799 Aufrufe, 14 Antworten
Hi everybody,
Is there a way to resolve the issue of not cutting the external part of the wall by the window opening?
Image below.
Many thanks in advance.
Elio
14 ANTWORTEN 14
Nachricht 2 von 15
martijn_pater
als Antwort auf: Anonymous
Did you draw them seperately? or did you use create parts on the wall? If so, why? What's the reason you're using parts?
Nachricht 3 von 15
als Antwort auf: martijn_pater
Hi  Martijn.
I created the wall, inserted the window and then exploded it into parts.
Nachricht 4 von 15
Alan.johnson1970
Can you post your model?
AJ.
Nachricht 5 von 15
als Antwort auf: Alan.johnson1970
Hello Sir,
I am not authorized to do it. Since it is a complex and large scale model. If I copy only the selected part of the geometries in another model, the problem does not persist.
Many thanks !
Elio Fetolli
Nachricht 6 von 15
martijn_pater
Still wondering if you should be using parts at all... But otherwise you could seperate the opening as part also and exclude it i think?
Nachricht 7 von 15
Hi Sir,
I need parts because the model will then be used for the quantity takeoff, so I cannot join the parts...
Nachricht 8 von 15
If they are two separate walls then join them and the window will cut through.
If it is a single wall, does the window cut through the wall before you turning it to parts?
- If so, parts should have the same hole as the wall
- if not, then the family uses a void instead of a cut opening. Edit the family and make the void longer, or replace it with a cut opening.
Nachricht 9 von 15
als Antwort auf: ToanDN
Hello Doan,
I tried all the options, but it does not work. I have copied the geometry in another file and it works perfectly, whereas in the file I am currently modelling it does not. What is your opinion?
Thanks again!
Nachricht 10 von 15
Parts is not the issue if your wall is cut properly.  If you change the view to Show Originals, does the window cut through the wall?
Nachricht 11 von 15
RDAOU
@Anonymous wrote:
Hello Doan,
Thanks again!
@Anonymous
Judging from the image you have posted in the original post, the shape handles indicate that the layer/part you have selected is already cut by the Window (Refer to the image below)
unless that element is part of something other than the wall and window (maybe a wrongly phased infill) and when cutting wall and window and pasting into a new file works; I would suggest that you have another look at the Phasing and the applied Phase filters (reset phase created of wall and window to same phase)
Nachricht 12 von 15
Hello Sir,
When I select show original, the window cuts the wall. When I select
show parts, the external part of the wall covers the window, while the
other two parts are being cut by the void...
Nachricht 13 von 15
als Antwort auf: RDAOU
Hello Sir,
I also checked the phases and they are coincident... So the problem still persists...
Nachricht 14 von 15
RDAOU
@Anonymous
Did you try to tab select the part in the middle and Reset Shape?
Nachricht 15 von 15
martijn_pater
Just a thought, what if you draw the outer layer outside your wall assembly (new type...) seperately and then join that. Wondering what happens then...
