The walls keep connecting even though i have placed a column in between
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
nicol_mukaj
1992 Aufrufe, 6 Antworten
Hello to everyone. I have created the walls and the column in between but the cut pattern of the walls keeps connecting, plus i have fixed the cut pattern of the column in the visibility graphics but when i connected the columns to all the levels their pattern dissapeared.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: nicol_mukaj
Disallow Wall Auto Join.  Also, open Column Family and uncheck "Automatically Join Geometry to Walls" to prevent the Column from auto joining in the future.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Nachricht 3 von 7
nicol_mukaj
als Antwort auf: barthbradley
the cut pattern of the column in the base level looks correct but in the other levels it just goes blank.
Nachricht 4 von 7
Could be a number of reasons why. Post your File.
Nachricht 5 von 7
nicol_mukaj
Beside this problem I don't know why does the wall line appear black when I set it to a different color as you will see in the file I uploaded13.PNG
Nachricht 6 von 7
I don't find any issues. Your Columns do have a Coarse Fill Color/Pattern, and the Views shown in your above 2 screenshots of "Level 0"  are set to different Detail Levels. One is set to Coarse and the other is not.  Get it?
Nachricht 7 von 7
nicol_mukaj
Thank you, I am very new to Revit :leicht_lächelndes_Gesicht:
