If I change my publish set I have to Save & Close before I can see what is in my newly selected set.
Here Set 1 is selected:
Here I've selected Set 2 instead:
Now I have to save&close and reopen the Publish Settings dialog box in order to refresh the views in the saved set:
Gelöst! Gehe zur Lösung
Gelöst von Mike.FORM. Gehe zur Lösung
I would probably qualify this as a bug.
You may want to report this by contacting support.
Actually, this is a Ideas Topic. Might even be on the Roadmap already. That dialog box needs a Save Current Set button.
The post The views and sheets in Selected Sets should update when a set is checked/un-checked in Publish Sett... was moved by kimberly.fuhrman.
