THE PIPE OF COLD WATER AND HOT WATER ARE HIDE IN 2D FLOOR
anass2010
anass2010
I work in mechanical template but i found
1- the cold ,Hot water pipe "system hot , cold water assigend" are hide in 2d floor as shown pic while the are appeared in 3d as shown
2-the other pipe are appeared which system fire protection or any system selected
amplogho
Open the Visibility/Graphics Override panel and navigate to the Filters tab. Make sure that there is not a filter that is excluding those system types from being visible in those views. If that checks out, then check that your view range is not cutting off your depth of field just above the pipe elevation. Visibility box is unchecked for the system type "Watershape Return"Visibility box is unchecked for the system type "Watershape Return"
anass2010
