Has anyone ever encounter a problem where the number inside of the door tag is a question mark or missing?
If so; did anyone find a solution?
Hi @Anonymous
Can you try the below steps for me and see if this helps?
1. Select an instance of the door tag.
2. In the Modify tab of the ribbon, click Edit Family.
3. Modify the tag in one of these ways:
4. Save the modified tag family.
5. In the ribbon, click Load into Project or click Load into Project and Close.
Looking forward to hearing from you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
The tag may not use the built-in Mark or Type Mark parameter, but a shared parameter. If the shared parameter is not added to the project parameters then the tag will report ?.
