The material of this structure realized with metric curtain panel pattern based families
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
f.annoscia1XRNMD
504 Aufrufe, 5 Antworten
Good morning. I do not know how to change the material of this structure. Can anyone help me? I have realized this structure with metric curtain panel pattern based families. Thank you.
https://forums.autodesk.com/t5/revit-architecture-forum/how-to-repeat-a-pattern-accurately/m-p/10758...
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: f.annoscia1XRNMD
Here you go. You just have to edit the this generic model
Then add material parameter
Nachricht 3 von 6
f.annoscia1XRNMD
als Antwort auf: syman2000
Thank you @syman2000. Can you help me with this? These diagonal beams, indicated with the arrow in red, are rotated 45° on their axis. They should be on the same level as the other beams.
In addition, the correct position of the truss is this (green), but in the file it is upside down. I have a hard time giving it the right direction.
Nachricht 4 von 6
syman2000
I would simply remove these original brace
Add new reference line and then host Famiglia11 to those lines
Create form and you will get those brace align straight
Nachricht 5 von 6
Thank you @syman2000 ! How long do you think it takes to learn to master these commands well? I've been using Revit for about 10 months, but I never feel like I know how to master it. And also for many aspects of the program, such as families, they are still at the initial level. I am self-taught.
Nachricht 6 von 6
syman2000
It is hard to learn these unless you diligently apply this to day to day work. Even I am not fully master everything parametric for adaptive. So I learn it by practicing and seek out the webinar from other industry expert.
