I keep getting this error message when I render in Cloud.
Error:
The following render appearance images are missing
Unified Bitmap.
UnifiedbitmapUI.xml
how do I get rid of this message?
Or how do I search for the Bitmap that is missing so that I can remove it or re-link it? I also get this error message in other files.
I have tried purging the file and only rendering one image at a time, bit no luck.
@Anonymous
Check the path under "R" icon in upper left hand of screen>Options>Rendering>Additional Render Appearance Paths
See if your PC has lost connection to the path listed here. This would cause the problem you experienced.
Or in alternate way,
Check the materials folder >> C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1\Mats
Its automatically created folder during installation (NOTE : During installation internet connection is required)
Try these suggestions let me know if its cleared.
Lakshman
thank you Lakshman01
I tried to add a new path, to our library, where all our materials are. But the message keeps appearing when i render unfortunately.
I also searched t the material in the autodesk folder but no luck there either.
This seems to be a common problem. Any other solution to how to get rid of this message?
do you have a linked Revit file in the project?
