I created a group for each unit ''apartment'' type. However, for one of the groups, the door doesn't show unless i click on the group. Can you advise? please see the two picture below to get a better idea
That door has been excluded from the group because it could not find a host when the group was placed. When you select the group you'll see this tab up in the menu:
Click on Restore All Excluded and if the door can find a suitable host element it will be included int he project again.
If the door does not get included with the host wall in the image as shown you'll have to investigate the position of the host wall and make sure it's in the exact same relative position to the group as the original wall.
check your view range or phasing?
Hi @mmostafaHKPP5
Thanks a lot for posting your question to the forums! Have the solutions suggested by @Lachlan-JWP @ennujozlagam helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
