The Command line has vanished. I tried ctrl 9 to restore, no luck
2 REPLIES 2
sdwinslow
228 Views, 2 Replies
Does anyone have any advice on how to restore the Command line?  Thanks!
2 REPLIES 2
Tom_Kunsman
in reply to: sdwinslow
Revit does not have a command line. AutoCAD does. If the Ctrl+9 does not work, minimize the window as it might have gotten moved out of cad - it has happened a few times. Might also move the taskbar in windows, sometimes it will hide behind that. Good luck
sdwinslow
in reply to: Tom_Kunsman
Oops - my mistake, I am using both at the same time and am starting to cross my issues between Autocad v 2024 and Revit v 2024 which I'm having various issues with since they were recently installed...Thanks for your help 🙂
