The color pattern is not showing properly; it looks faded or like a halftone.
kenan_alazzeh
Message 1 of 8
kenan_alazzeh
"I am working on an architectural view for wall details, and as shown in image 01, the colors for the pattern look faded or like a halftone. Taking into consideration that the halftone option is off in visibility/graphic settings, while if I use a solid fill, the colors appear fine. I have attached another image from a different project where the color pattern shows properly.
Any solutions?"
Replies (7)
Message 2 of 8
RDAOU
@kenan_alazzeh
There are no images attached.
did you check the view’s discipline? Filters? phasing?
Message 3 of 8
kenan_alazzeh
i attached the image now and all mentioned check i am also using filter to give pattern as per type.
Message 4 of 8
RDAOU
@kenan_alazzeh
Is this in the entire project ie: all views (it might be a Project Template spec)? or just this specific View? If the latter, try to
  • Either recreate the view (not desirable if you have worked out lots of detailing on the view)
  • Or create a view template from the good view and apply that to the bad one?
  • Add if it is a project template issue where no good views in the current project, create a view template in a project where the views are good then use transfer project standards to load it into the bad model
Message 5 of 8
Simon_Weel
What if you duplicate (without detailing) the view and remove all filters from that duplicate view - how does that show up?
Message 6 of 8
kenan_alazzeh
this is in all project
Message 7 of 8
kenan_alazzeh
look same i removed the filters and just override by elements still look same
Message 8 of 8
RDAOU
@kenan_alazzeh
Then it may be template related ... See previous reply; try to create the view template in the project where the view is good and then go back to this project and use transfer project standards to get that template in and apply it
