the checkbox is not available in: Create new local file in worksharing
1 ANTWORT 1
Nachricht 1 von 2
363 Aufrufe, 1 Antwort
Hey Autodesk
I have make the central file the right place. But 2 of my group-members cannot set af checkmark in: Create af new local file. It works for the other 2 menbers. We have ben doing the same thing to get acces. How can it be?
1 ANTWORT 1
Nachricht 2 von 2
Kimtaurus
als Antwort auf: Anonymous
Is this a constant problem? Sometimes restarting Revit helps. It could be the central file is in use (someone's syncing) and you can't create a local at that moment.
Other possibilities:
- Is everybody working in the same Revit version?
- Is the file path name for the central file the same for everybody? We've had cases where a server had a different name on a colleagues computer, as a result they couldn't work on the work-shared file.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
