The Autocad text is not visible in the Revit.
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
B-CM_Jeong
1101 Aufrufe, 6 Antworten
The "FCU" text written on the AutoCAD is not visible in the Revit.
Neither LinkCAD nor ImportCAD are visible.
I tried to disassemble all objects using the "explode" and "burst", but I can't see them.
I appreciate your help
6 ANTWORTEN 6
Nachricht 2 von 7
L.Maas
als Antwort auf: B-CM_Jeong
Try to replace the font in the Autocad file to something like Arial and see if that helps
Consider to upload the CAD file so we can have a look.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 7
I think Annotative text is not compatible with Revit.  It's been a long time so I forget how to fix it without AutoCad.
Nachricht 4 von 7
B-CM_Jeong
Upload dwg file
Nachricht 5 von 7
B-CM_Jeong
als Antwort auf: L.Maas
I uploaded the cad file Please check
Nachricht 6 von 7
B-CM_Jeong
als Antwort auf: ToanDN
too many information wrote by annotative text. I couldn't fix it. OMG
Nachricht 7 von 7
L.Maas
The issue is that the elements in Autocad is not text. These are attributes. Similar to a parameter/field definition.
However the definition does not contain a value
When I convert it into a block
It then asks me to enter attribute values
And after that, saving and linking into Revit
Louis
