Hi, everyone
Font in my type selector and type show rectengular (picture) after install Revit 2019. Before this I use Revit 2018 on same machin and revit show font normally. and Rectengular show only thai font.
help please.
A few questions for you.
I look forward to hearing from you. Glad to help!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you for your response!
No worries, can you specify the font name? We can reproduce the issue on our end and work towards a resolution.
Viveka CD
Does the font display irregular in your keynotes or just type selector?
Here's some feedback from the team:
The rectangular boxes display when trying to use Thai characters in a font that doesn't support them. In your case, Revit has to do a font substitution. If you used a font that actually supported the Thai characters, substitution wouldn't be required.
Please specify the name of the font, so we can troubleshoot further.
Viveka CD
The rectangle box means the font does not have the character set for the Thai characters. I would switch the font to Arial Unicode MS, or a Thai specific font.
