I had this problem that, when I create mirrored group, the texture tend to rotate uncontrollably.
I had this problem multiple time, thus made me always avoid using grouping method whenever I can. But this time I do really need a grouping since the geometry are mirrored and complex.
Is there any way I can do to keep the texture aligned with the original group?
Thanks in advance
i'm not quite sure, but perhaps if you control the rotation of texture (Materials browser / Texture editor) in a way that keeps aligned perpendicular to mirror axis it may work. Also try with Link texture transform option.
Thank you for your answer, but this still doesn't work.
Anyway, to gave you some context, In my company I worked, there is a policy to create the model not align with X Y axis, like the picture i shown below
Is there any correlation regarding this method? or do you had any solution?
Whatever your answer is, thank you for giving your time to think about this!
