Texts can't be selected on region area
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
fangirlinga5
519 Aufrufe, 6 Antworten
Hello!
I have a problem with Revit, this happens to every element on the surface of a region area.
I am trying to select the text below (highlighted in a red box), but I cannot select itwhen it's on the surface of a masked region. I can't edit/move/copy etc. the texts.
This problem did not occur before, I do not know if I unselected something.
Thank you in advance.
6 ANTWORTEN 6
Nachricht 2 von 7
blank...
als Antwort auf: fangirlinga5
Hover over text and press tab doesn't work?
Nachricht 3 von 7
fangirlinga5
als Antwort auf: blank...
It works! Thank you very much!
Moreover, is there a way to do this without having to click tab? It's my first time experiencing this as this didn't happen before.
Nachricht 4 von 7
blank...
Not that I know, as far as I know it's always been like that. Maybe one of us is misremembering.
Nachricht 5 von 7
fangirlinga5
I see, I just updated my Revit maybe what I am saying is just on the older version.
Thank you so much and bless you!
Nachricht 6 von 7
Check options to control element selection.  Maybe disabling "by face" will duplicate the behavior you experienced in the past.
Help | Options to Control Element Selection | Autodesk
Nachricht 7 von 7
fangirlinga5
IT WORKS! Thank you! I might have unknowingly selected it.
