Texts and Wall Tags Error
1 ANTWORT 1
Nachricht 1 von 2
TAScottArchitecture
202 Aufrufe, 1 Antwort
The text in new 2017 Revit has some issues:
1/ Lets say the word is "Safety Post" in the textbox, but the textbox will only show the word "Safety" in both Revit program and when PDF. I have to find the textbox and click on it for the both words to appear.
2/ When PDF, the last problem I encountered was the wall tags. They didn't show up when I printed them as PDF. This causes quite a trouble.
I hope this makes sense and thank you for your time.
Lee
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: TAScottArchitecture
Hello, Lee.
We're using Revit 17 at our office and we haven't found these issues.
Maybe your graphic card is providing these visual problems into your model.
I recommend you to check your Tag family. Check if the parameter defined into the Label it's the correct one.
Any doubt, I'm available.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
