Posting this on behalf of @Dougp
My company skipped 2017 and just upgraded from 2016 to 2018 and have this text wrapping issue. Is there something we can do in this situation? Thanks!
Any feedback is welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Dougp
Can yous hare a file to test further?
Viveka CD
They changed the font size measurement since Revit 2017. If you open a 2016 file in 2017 or newer, you have to reduce the text heights a tiny bit in order to maintain the existing text wrapping.
My recommendation is keep 2016 projects in 2016 and start new projects fresh in 2018 or 2019.
@Anonymous
Please see the below articles:
Text is wrapping in Revit 2018 on one computer
Font compatibility for Autodesk Products
Viveka CD
16 to 17 was the text issue change. I found a quicker fix than selecting each text box. From memory i selected a text box, then selected all instances of that type. I think i then did a small pull on that that text box to widen it. Then click out. Something like that worked for me and did it to all etxt boxes in that view of that type at once. Sorry i can i cant remember exactly, but give it a try.
Hi there @Dougp
I have not heard back from you in a while., just checking back on your issue.
Let us know if the recommendations helped or we can assist you further.
Viveka CD
@Viveka_CD wrote:Hi there @Dougp
Viveka CD have you found a solution to the text wrapping problem or a hot fix for Revit 2018.3.3 when converting a Revit 2016 project to Revit 2018?
