Text Vertical Offset in Schedules
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Crow_T_Robot
318 Aufrufe, 4 Antworten
I currently have a schedule with very tall rows. I want to center the text within these rows vertically, but I can not find a way to adjust this (see attached image). Is there a way to change the vertical offset of text in a schedule, or is it just a fixed distance? Thank you.
-Stephen Revit 2022 Intel(R) Core(TM) i7-8700 CPU @ 3.20 GHz, 16.0 GB Ram, NVIDIA GeForce GTX 1050 Ti, Windows 10
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Crow_T_Robot
Do you have hidden columns with data the occupies more space than that?
Nachricht 3 von 5
Crow_T_Robot
als Antwort auf: barthbradley
Hi @barthbradley ,
Yes, I do have a hidden column with data that has larger text.
Nachricht 4 von 5
Well, if they are Hidden, just override the Font used in those Columns.  Make it super small.
Nachricht 5 von 5
@Crow_T_Robot wrote:
Hi @barthbradley ,
Unhide the column and stretch it wider to reduce the row heights, then re-hide it.
