Text Sizes in different Projects
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
heiserdrafting
326 Aufrufe, 5 Antworten
Lets see if I can explain this.
I have a first project. I placed room labels and this turned out great. I see it is set to 1/16" Arial (Bold).
For reference I placed a 1' box...
This was my first project, afterwards I saved what I did as a template so I could continue to use everything I has already set up.
My second project I placed a room label. Same label as project 1. 1/16" Arial (Bold). As you can see, it is a lot smaller.
Am I crazy? Maybe.. but what am I doing wrong here? Thanks everyone!
5 ANTWORTEN 5
Nachricht 2 von 6
hmunsell
als Antwort auf: heiserdrafting
Double check the scale of your views?
Howard Munsell
Nachricht 3 von 6
TripleM-Dev.net
The 2 views have different scales? (or different tag types?)
Textsizes in Revit are in "sheet sizes".
This means views at different scales will display the text at identical sizes on the sheet.
- Michel
Nachricht 4 von 6
How do we judge something like this from a screenshot? Do they both print the same size?
Which dime is bigger?
Nachricht 5 von 6
heiserdrafting
als Antwort auf: hmunsell
thank you for the reply, that did it.
Still learning Revit, did not even think to look at the different scales for each view.
Nachricht 6 von 6
heiserdrafting
als Antwort auf: barthbradley
@barthbradley  That's why I placed a reference with the 1' box...
