As you can see, I have some text on an elevation. To make this more readable, can you change the bounds of the text box so that the text is all on one line rather than have the 1 under the rest of the text? Or make the text marginaly smaller perhaps?
Solved by dferreira-blackwell. Go to Solution.
Go to the Project browser, Click "+" beside Families, Click "+" beside Annotation Symbols, find Level Head Circle, select it--->right click---->edit---> select the textbox for Name enlarge as needed.
