text size changes
2 ANTWORTEN 2
Nachricht 1 von 3
noconnorG728Y
249 Aufrufe, 2 Antworten
text size changes
I have an issue with changing the Text size with leader. When I changed the size from 1.5mm to 2mm, the leaders get messed up. Straight leader to crooked leader. See image.
Is there a way to stop this from happening? TIA
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: noconnorG728Y
 individually remove and add new leader to realign
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
jay_colcombe
This is due to the Text Alignment and the start of the leader having no real association unlike AutoCAD so when the Text Height is increased/decreased the Leader line moves with the Text position but the Arrow head node does not!
2025 has a new tool for such issues
Help | Multiple Alignment | Autodesk
Jay Colcombe
Autodesk Certified Instructor
