Text scale adjusting after PDFing
6 ANTWORTEN 6
Nachricht 1 von 7
dan.buckingham
617 Aufrufe, 6 Antworten
Hi all, struggling to find a reason/solution for this one.
In my practice we use the DiRoots extension ProSheets to batch export PDF & DWG files, and it's been working like a dream for years.
However, on my latest batch of drawings, I've noticed all my text and tags are rescaling and getting much larger after PDFing. Below is an example (left is Revit, right is PDF of same drawing).
I've had another user Pdf the same drawing using the same extension with the same format & profile, and all is fine, so it must be a settings change on my PC.
What setting/option would cause something like this to happen?
6 ANTWORTEN 6
Nachricht 2 von 7
L.Maas
als Antwort auf: dan.buckingham
Some things tro try
-Use "Raster Processing" in your print settings. See if it makes a difference.
-Change your font for some texts in Revit to something different and common (e.g. Arial).
It might be an issue with fonts installed on your computer or settings in the PDF printer.
-Change to a different PDF printer. Same issue or not?
If it has worked before, what has changed in the mean time on your computer?
Other projects have the same issues?
What happens with a printout in another Revit version?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 7
dan.buckingham
als Antwort auf: L.Maas
  • I can try raster processing, but it works with Vector for other users, and I need to be issuing as Vector PDF
  • Text and Tags are already Arial throughout the project
  • Tried various print setups, no change
  • We have recently upgraded the project from Revit 2020 to 2023
  • This is affecting all 3 models of this project
I don't imagine the upgrade will have affected it, as I have issued drawings since then with all being fine.
Nachricht 4 von 7
juliar123
It could be the actual print functionality.
Try using the File>export>PDF function in Revit 2023. Don't use the print tool.
Nachricht 5 von 7
dan.buckingham
als Antwort auf: juliar123
Thanks, but I'm using a third party extension.
I've found that simply uninstalling and reinstalling the plugin solves the issue, so I presume it was an issue with DiRoots itself
Nachricht 6 von 7
mhiserZFHXS
Why continue using a 3rd party extension when Revit can do it natively now? I wouldn't be surprised if that function is no longer being maintained in diroots since its not needed anymore.
Nachricht 7 von 7
dan.buckingham
als Antwort auf: mhiserZFHXS
Trust me, its on my to-do list to set up the format natively!
Can Revit now natively do PDF and DWG exports in one process, in the same way DiRoot currently does? Or do I need to create a dynamo tool for that?
