Text print is huge in Revit LT 2019
mattVGBFC
mattVGBFC
I am having a problems with text printing at the right scale with Revit LT 2019.  The text is being printed out huge.
Accepted solutions (3)
aRcHiTeCt.JM
.... click and turn blue the viewport
.... in the viewport change the scale
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Matt__W
@mattVGBFC check out this AKN article for information regarding where to find any available product updates as well as information about how to install them. Want to ensure you have the latest updates installed for Revit 2019.
INSTALL UPDATES, ADD-ONS, AND ENHANCEMENTS
https://knowledge.autodesk.com/customer-service/download-install/install-software/update-software/en...
Let's also make sure you have the latest graphics card drivers installed.
UPDATE DRIVERS IN WINDOWS 10
https://support.microsoft.com/en-us/help/4028443/windows-update-drivers-in-windows-10
Lastly, check for any available printer driver updates and install them.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Corsten.Au
You may edit the View Title..
thats the Tiltle with line family, using " View Title : M_Title, find this in the families..thats the Tiltle with line family, using " View Title : M_Title, find this in the families..Edit the main Family... you cannot select the sub, type and edit..Edit the main Family... you cannot select the sub, type and edit..Change and save as new family and use this in Duplicated System family " Ex Title w Line R2 "Change and save as new family and use this in Duplicated System family " Ex Title w Line R2 "
Corsten
Building Designer
Viveka_CD
Hi @mattVGBFC
Welcome to the community!
I'm just checking back to see if the recommendations helped resolve your issue? If so, please marks relevant posts as 'accept as solution'
Let me know if you have additional questions!
aRcHiTeCt.JM
.... did you get your answer?
.... if you try these options below you will get your solution
aRcHiTeCt.JM
REVIT EXPERT ELITE
Have you found a solution for this?
We are having the same issues.
I have Revit 2019 LT running on Windows 7, in a virtual machine, using VirtualBox on a Late 2013 IMac.
It did the same when making PDF when we had Revit 2014, but only in PDFs. Now it is when I go to print on a plotter.
