text orientation in family
2 ANTWORTEN 2
Nachricht 1 von 3
316 Aufrufe, 2 Antworten
Hello people please see attached files, i have a door family which has a detail family within it(the orange circle and LT symbol). The problem is if I flip the door a certain way the text is mirrored and doesn't display right. Is there a way i can always have the text orientated correctly regardless of door orientation.
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: Anonymous
Are those text Model text? If yes, you may want to create two different model text mirror and not mirror. Then you can turn ON/OFF those object.
If you don't want to do that, you can use the embedded Generic annotation symbol. However this method only works for plan and won't work for elevation.
Nachricht 3 von 3
jvpantin2
Hi! You should use label instead model or annotation text. With labels you can use a fixed value or parameter, define orientation and where you want to see it (floor plans, RCP's or elevations/sections).
Read this post for more info:https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
