Text or label in generic model family
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
piotr.spyra
3672 Aufrufe, 3 Antworten
I'm trying to make a generic model family (prefabricated balcony) witch includes text/label. I have found something like annotation that I need (link belove):
https://forums.autodesk.com/t5/revit-mep-forum/text-in-family-not-printing/td-p/7242195
but it doesn't work with in my project. Can't find mistake, so I need to ask You for help. I would like to see the text (1) on the plan view and make the line (2) visible as dashed.
I've created subcategory in family editor, how can I import this line to the project "object styles" option?
I will be thankful for any sugestion.
Best regards
Piotr
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: piotr.spyra
The label parameter in the annotation family should be an Instance parameter.
Nachricht 3 von 4
It loads into Project with the Family
Nachricht 4 von 4
piotr.spyra
als Antwort auf: barthbradley
Thank You! It works perfect :leicht_lächelndes_Gesicht:
