Can someone explain how to have a consistent offset on Aligned dimensions? If I create an aligned dimension that is not horizontal or vertical the offset seems to change.
This is the Text Offset field under the Text area of the Dimension style -
Please advise. Thank you.
Regards Peter.
What about two Dimension Types; one for Aligned with a slightly greater offset to compensate for the inaccuracy between the two?
It seems to get smaller as you rotate it. Just hoping there was a setting or something? any more thoughts? I'd rather not create multiple dimension styles for this issue.
Cheers Peter.
Yah, it looks like about a 1/64" difference at 1/8"/1'-0" scale.
Does it really stand out in context to the overall View? I know when you zoom in tight the difference is noticeable, but how about when you zoom to fit?
