If I delete the text from a textbox and then try to write, nothing gets written.
that is strange??? try to install latest updates from autodesk and untick use hardware acceleration from options and see if helps. thanks
Quite often I tried to type but nothing happened, have to exit the text and edit again.
I find using Backspace will delete selected text and allow for typing immediately whereas occasionally using Delete instead doesn't allow me to type new text or when just selecting text and attempting to type something to replace is doesn't work either. Quirky.
Steve Stafford
This seems to be the new procedure for editing text. Very annoying to change this all of the sudden. Yea we can adjust our workflow and reprogram our muscle memory but this should not happen because of a software update.
Stuff like this is like putting a pebble in a marathon runners shoe that they cant get rid of.
