****Note: while drafting this post, I continued to try a few more troubleshooting options and found the source of the problem. Because I could not find this issue on other forums, I decided to post it anyway along with the solution below.
Starting a few weeks ago, some of my text boxes won't print correctly. Some of the fill patterns for arrowheads on text leaders print offset from the end of the leader line. Additionally, the masking region will cover parts of the text and model/drafting elements.
Here's what I know:
Gelöst! Gehe zur Lösung
Gelöst von robertDCZNB. Gehe zur Lösung
It turns out this was caused by the Print Quality settings for the Bluebeam printer driver. Anything 720dpi and lower printed correctly. The problem started at 1200dpi and got progressively worse at higher resolutions. Folks in my office changed their settings and recreated the printing issue.
