Hi There,
I am having an issue when printing to PDF and printing to a printer.
The text appears different compared to how it appears in Revit - this can be anything from the text leader not attaching to the text, the text appearing a smaller size, or buched together.
I have attached an example of the below
1. Revit sheet printed to pdf from my computer (text leaders dont print correctly)
2. Screenshot of the exact page in revit
3. Same revit sheet printed to pdf from my collegues computer (appears correct)
My computer and my collegues are the exact same - same graphics card and same revit.
Any help is appreciated.
try to use another printer driver like BULLZIP and see if helps. thank
Hi, Thanks for your message
I have tried the following and all have the same result:
Print to PDF
Bullzip
CutePDF
AdobePDF
the same printer driver? or the same build also? like this one. this is just a example and it depend your revit version
Your right - they are different.
Is there a way i can change mine to be the same as my collegues ? (to check if the print settings work )
THanks,
install the latest updates from autodesk. check the other computer what is the latest updates from autodesk. thanks
