Hi
I have a problem with text in revit.
After creating a text in hebrew, sometimes half of the text is missing, and appears again after moving.
The problem is, it's not just missing in the revit- if I print it to pdf it still not visible.
Attached pictures of a text that's missing, and after moving it.
Why is it happening? And how to prevent it?
Not sure why it is happening. Might have to do with that hebrew is a language written from right to left. That might cause issues in Revit.
What happens when you increase the size of the textbox?
Also play around with text align (left, center, right) and see if that has an impact.
Louis
Please mention Revit version, especially when uploading Revit files.
Try:
-Setting the text scaling to 100%.
-Changing a type property from the text (Example make it Bold) hit apply. You can then un-check the Bold box and hit apply again.
What Revit Version is this?
