I ran into a problem. When I make a detailed plan, I use the text tool.
I use a very large text (100mm). In this case, I cannot create a text field larger than 212.
Is it possible to correct this. This is really not very practical.
Thanks for your help
Bests regards
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Text tool is for annotation (paper scale). I think you need to use Model text.
Just looked at you pic. never mind. And why does it need to be 1:1? Are you trying to do a life-size poster or something?
The view scale doesn't need to be 1:1 for an image and text overlay. Change the scale and then use a regular text height based on printed height. If the image is too small in the different scale view you can resize the image instead.
Steve Stafford
Indeed, if there is a size restriction for the width of the fields. I need to make it 1:10.
I hope Autodesk will remove that limit in the future.
Thank you for your feedback.
