Hi everyone,
I am trying to create a custom layout in revit and it is not happening as it should.
The autocad file in discussion is just a layout with textfields in it. I want to create a custom plan templet in Revit from this Autocad file. The way I proceeded is this:
I created a .dwg consiting of just a layout with text in it in the model area. Then I purged the acutocad file of any extra layer or linetype. Then I imported the said .dwg to a new family in Revit. I used a layout templet from revit for this. Now the problems:
Please let me know how can I copy this layout from Autocad to Revit to create quickly a custom Templet.
@barthbradley , @syman2000 , @ToanDN , @ennujozlagam @constantin.stroescu
Thank you.
use this title block family and modify to suit your needs. revit scale is 1:1 and see if helps.
share the dwg titleblock
Hi @ennujozlagam, thanks for the reply.
I am using the same title block but the problem with the text exploding out of their respective places still exists. At this point, my only viable choice is to delete all the text and write it again in the revit templet. Please let me know if there is any better option to save time.
Thank you.
