I'm not sure if this is the best place to post this, but I noticed some odd functionality with the text editor. I tried toggling the bold and underline buttons, but it only seems to work for a selection of characters rather than bolding as I type. Is that a bug or is that how it was intended to work?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
That's how it works for me as well. Why do you think it's a bug?
BTW: What Version are you using?
You could do it this way too (e.g. set Bold and Underline as the default).
I'm just used to being able to press ctrl + B and then typing in Bold rather than going back to select it after I've typed it. I figured that was the standard so it seemed like a bug to me. Especially since you can continue to type in bold after bolding the selection. Anyway, it's just a minor thing I noticed. Thanks for the verification.
