Text box orientation
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Clyndr
450 Aufrufe, 4 Antworten
I am trying to align the direction of text along the dimension. How can edit the direction of text along with the dimension?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Clyndr
Did you try the Read Convention Property Parameter of the Dimension Type?
Nachricht 3 von 5
Clyndr
als Antwort auf: barthbradley
I am trying to change the read conversion for the text box (the dimension of pipe indicated in the screenshot above). Is there any existing command or parameter for textboxes?
Nachricht 4 von 5
Select Text and uncheck "Keep Readable" in the Properties.
Nachricht 5 von 5
Clyndr
Thank you. Solved!
