[Tested Issue] where split section doesn't cut through generic model
4 ANTWORTEN 4
Nachricht 1 von 5
20719085
416 Aufrufe, 4 Antworten
Hi Autodesk Revit Dev team,
We've come across an issue at work where an imported generic model (from rhino 5) doesn't show up in a section view where it's a split section cut. We've tested them against a clean straight cut and it's pretty clear that the split is causing the issue.
Can the development team look into this and patch it in the next update?
Thanks in advance.
Xinyi
4 ANTWORTEN 4
Nachricht 2 von 5
RobDraw
als Antwort auf: 20719085
This is a user help forum. There are better ways to contact them as they may only occasionally visit here.
Good luck!
Oh, maybe you can try asking the users if anyone has come across this issue as well. Maybe they have a solution.
Rob
Nachricht 3 von 5
Nachricht 4 von 5
20719085
als Antwort auf: RobDraw
Thanks Rob. Have already done so. Hopefully will hear back from them.
Thanks again!
Nachricht 5 von 5
20719085
als Antwort auf: barthbradley
Thanks barthbradley! We've tested the method described in the link but it didn't work either (2018/2020 versions). We've reported it to the autodesk team. Hopefully will hear back from them.
