I have a building with one underground level, when I try to make an RCP of such level, I don't see the terrain/topography, but the bottom of the modeled entourage floor above (sidewalks, streets, etc).
I checked the vv options and the view range. Pads are also modeled correctly and the topography element/category are not hidden. Am I missing something?
Thanks for any help.
Attached is a *very* crude drawing of what shoud the drawing be
Gelöst! Gehe zur Lösung
Gelöst von manuelmunoz87. Gehe zur Lösung
It's not clear what you are saying. Are you saying you can't see Toposurface in the view? Is it turned on and within the View Range?
As it turns out, the solution had to do with none of my toposurface points being inside the level's view range. I had to add an extra point to my toposurface that was lower enough to be inside that view range, and DONE!
