I am using Revit 2020.2 on Windows 10.
I have noticed that if a user has activated the Temporary View Properties on a given view and temporarily assigns another view template, Revit will automatically add the said view template to a "Recent Templates" list (see image below).
The issue is created when a user syncs while having an active Temporary View Properties (and NOT using any of the templates on the Recent Templates list): Revit will disregard the user's temporary VG changes and will automatically change the VG settings to the first template on the "Recent Template" list after the sync.
I was wondering if there is a way to fix this behavior in Revit OR is there a way to simply remove the view templates that are stored in the "Recent Templates" list?
Recent Templates: Displays a list of the last 5 view templates that you have used. Select one to reapply it to the temporary view
it's a good one
but if you need to remove them first
save the project beacuse you will need it
then
View
manage View Template
Delete the View template that Displayed
they will removed for the temprory view template
then
Transfer the View template again from the File yo save
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Hosam Elzohry , ACI , ACP, Autodesk Ambassador Gold
BIM Manager
