I am having trouble with temporary dimensions. They show up when I select a wall, but not when I select an opening (such as a door, window, etc.). Also, I am unable to change the location of openings using non-temporary dimensions (Like when you select a window/door and it allows you to define a distance on a dimension you created with the "aligned" tool). All this is making it difficult to change the location of an window/door once it is placed. The only way I can seem to do it is with the EQ function , or just slecting the item and manually moving it with my mouse and guessing at distances.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
