Temporary dimensions won't snap to wall face.
7 ANTWORTEN 7
Nachricht 1 von 8
1797 Aufrufe, 7 Antworten
The temporary dimensions in that particular corner will always stay in the center even after after setting it to wall face. Any idea why? Thank you very much.temp dimensions.PNG
7 ANTWORTEN 7
Nachricht 2 von 8
idrisbahadur
als Antwort auf: Anonymous
You can change the temporary dimension settings as you want by following this:
Manage > Additional Settings > Temporary Dimensions
From the dialog, you can select Faces for Walls:
İdris Bahadur
Nachricht 3 von 8
als Antwort auf: idrisbahadur
Thanks. Yeah, I did that. I t works for all other dimensions but not when it's at a corner like in the image.
Nachricht 4 von 8
idrisbahadur
There is no other specific settings for temporary dimensions. Unfortunately, you need to drag the blue points manually for those minor places.
İdris Bahadur
Nachricht 5 von 8
Can't drag it either.
Nachricht 6 von 8
idrisbahadur
I know it's very basic but you can just put a dimension, click the wall, enter the value to dimension. Sometimes, it's good to do any method and move on another topic :leicht_lächelndes_Gesicht:
İdris Bahadur
Nachricht 7 von 8
Lachlan-JWP
In this case, the temporary dimension is locked to the length of the wall, which extends to the core centreline of the wall it is joining. There isn't a way to change it. This is a case where you'll have to use a workaround. I just create my own dimension. If it's so vital to get thelength of the wall correct, then you'll usually want to show that dimension on your documentation anyway.
Nachricht 8 von 8
als Antwort auf: Lachlan-JWP
Interesting. That makes sense. Thanks.
