Templates and families not installed
3 ANTWORTEN 3
Nachricht 1 von 4
1373 Aufrufe, 3 Antworten
I installed Revit 2015 and I can't find any familes installed under my computer exept for this rout: C:\ProgramData\Autodesk\RVT 2015\Libraries\Singapore
(I don't need Singapore...I need US metric)
I installed revit here: D:\Program Files\Autodesk\Revit 2015
How can I install all of this families?
(I already tried this guid of yours - http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
But i got stuck at the first step - I didn't find the 'Autodesk Revit Content Libraries 2015').
I have another question regarding the Revit Structure Steel Connections extention:
I'm not able to download this extention. what am I doing wrong?
How can I get this extention??
Thanks in advance,
Elad
3 ANTWORTEN 3
Nachricht 2 von 4
jitu1dange
als Antwort auf: Anonymous
Is your problem resolved?
It helps when you install Revit without internet connection. Because it requires internet to download Templates, components and material library. I would suggest you go to add or remove program, Select Revit click uninstall, and then select the option of reinstall, make sure you have active internet connection with good speed other wise it won't download the templates and will skip it and continue with the installation. So make sure you are connected to internet preferably wired.
I hope this helps.
Nachricht 3 von 4
jitu1dange
I hope this helps.
Nachricht 4 von 4
ennujozlagam
@Anonymous hello, you can try to check it HERE on how to install families and templates. hope it helps. thanks
