template problem
10 ANTWORTEN 10
Nachricht 1 von 11
479 Aufrufe, 10 Antworten
template problem
can anyone help with this been working on a template for a while now and when i come to use it it now says its been save in an older version?
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
What make this most strange is the fact i am in 8.1 and been working ans saving using 8.1
Nachricht 3 von 11
Sahay_R
1) Do you have any backups that you can rename and try to use?
2) Is there an old project that you can strip out and re-use?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 11
kadmonkee
was the template opened in a FULL version of Revit? (not LT)
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 5 von 11
als Antwort auf: kadmonkee
no i only have revit LT and i even have the template file open in my revit the problem occurs when i try and use it as a template
Nachricht 6 von 11
chrisplyler
So you don't get an error when you save the file and open it as a project.
You only get the error when you've saved the file as a template and then try to start a new project using that template?
Nachricht 7 von 11
als Antwort auf: chrisplyler
Yes exactly
Nachricht 8 von 11
chrisplyler
I see. Well, I don't know how to solve that problem.
But as a workaround until you can solve it, you may of course start a new project by opening that project file and immediately doing a save-as with a new project file name.
Nachricht 9 von 11
Viveka_CD
Hi @Anonymous
Please see HERE for a similar discussion
The primary cause is that Revit LT couldn't open older families or project files prior to 8.1, because there was no BasicFileInfo stream in them.
The solution would be to use a full version of Revit to open the file. You can download a trial of the full version and use it for 30 days.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Nachricht 10 von 11
als Antwort auf: Viveka_CD
this is a ridiculous idea, so to use my template i have created in LT i need to download full Revit? i thought files opened in full revit couldn't then be opened in LT ??
Nachricht 11 von 11
Sahay_R
Download the trial version. Open, save your template. Live happily ever after.
Rina Sahay
