Hi All have a frustrating problem where i can edit labels in my template, load into my project and some of the labels remain unchanged (drawn by & Checked by labels). I can change manually on each sheet via the properties panel but i want to change the template permanently, appreciate some help
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Are you talking about the Titleblock Template; specifically the default values being assigned to the parameters in the Project (e.g. "Drawn By" = "Author")?
@Anonymous wrote:
Yes talking about the title book and those 2 specific parameters
So, you just want it to read the same on every sheet in every project it is loaded? In other words, you do not want the ability to change it. If so. delete it and replace it with a text note.
...you know that you can easily manage all those entries through a schedule. You don't need to go sheet to sheet to change.
