Revit 2017 trail has been download bu when opening a new project there are no template file listed and shows as <none>. When using the browser tab to locate any other template file nothing is available on the screen that comes up which should list the template files. Can you help me how to fix this.
Default path for project template files:
C:\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\default.rte
C:\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\Construction-Default.rte
C:\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\Structural Analysis-Default.rte
C:\ProgramData\Autodesk\RVT 2017\Templates\US Imperial\Mechanical-Default.rte
