Template Bathroom
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
theresatlninhMWWN4
330 Aufrufe, 7 Antworten
Template Bathroom
I want to create a bathroom to use in multiple drawings with tag and dimensions on elevations, so when I copy it to different drawing, I don’t have to tag and put dimension for the elements again when they are in new drawing to save time.  What will be the best way to approach this?
Thank you,
7 ANTWORTEN 7
Nachricht 2 von 8
David_Knight
als Antwort auf: theresatlninhMWWN4
Group it all.  then create a detail groups for plan (and elevation? I've never done that, but I'm assuming you can) that are assigned to the model group (bathroom).
then you can copy/paste the groups from Revit file to Revit file.
Nachricht 3 von 8
You can create the bathroom model in the project, annotate it, select the bathroom model and its annotations to create a group then you will have a model group with its attached detail group.  Place this model group in other locations then you can select them and choose to add Attached detail group to them from the ribbon.
Nachricht 4 von 8
theresatlninhMWWN4
als Antwort auf: ToanDN
I was able to do it. One problem I ran into is several element attach to
wall, but I only want to copy the group without wall into new project. Can
I do something else to replace the wall so it is invisible when I copy to
new project?
Nachricht 5 von 8
Use face based or work plane based families instead.
Nachricht 6 von 8
handjonathan
Hi @theresatlninhMWWN4
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 7 von 8
theresatlninhMWWN4
als Antwort auf: handjonathan
I was able to make it work using group.  Thank you!
@ToanDN @handjonathan
Nachricht 8 von 8
handjonathan
Great to see you got it resolved @theresatlninhMWWN4
Jonathan Hand
