I am not understanding why the selection of a verical wall section brings up a horizontal temp dimension or vice versa.
Selection of a horizontal wall brings up a vertical temp dimension.
What is the proper technique to select a vertical wall and have the vertical temp dimension appear?
Tim
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Are you referring to this behavior?
See attached image for behavior I am trying to explain.
It looks wrong to me, but not the way you mean. I would expect a string of vertical dimensions. Not Horizontal.
...looks like I'd be disappointed too. No string.
So I guess the approach is to click the object you want to set the length of and if the wrong temp dimension appears you click on nearby perpendicular objects until the correct temp dimension appears.
I guess I was expecting the temp dimension to be in the orientation of the selected object.
Tim
Temporary dimensions prioritize the location of the selected element. Only when it does not find any relationship location wise, it shows the element dimension. So if you have only a wall in the view, nothing else, then when you select the wall, the temp dim is the length of the wall.
