hi all.
I have created a sheet list in revit.
I want to import in one on those a technical report and analytocal report written in word.
How can I do?
Gelöst! Gehe zur Lösung
Export the Sheet list that you have created (file/Export/Report) and open it with Excel. Then select the cells and import them into Word as a table.
You can open the export directly from Word, but it will be all over the place.
You can't import a Word document into Revit. But you can copy the text in the document and paste into Revit on the sheet that shows your schedule.
