Tech preview - Parameter Service - Adding parameters to Labels in Tags
3 ANTWORTEN 3
Nachricht 1 von 4
jens.lathouwersMR29R
337 Aufrufe, 3 Antworten
I'm testing the Parameter Service in Revit 2023.0.2. According to the documentation it should be possible to add a parameter from the parameter Service to a Label in a Tag Family. I can't seem to find how to do it. Did anyone succeed in doing this?
The documentation mentions:
You can add parameters from each of the following dialog windows:
  • Project Parameters
  • Single and Multi-Category Schedules
  • Material Takeoff Schedules
  • Sheet List Schedules
  • Note block Schedules
  • View list Schedules
  • Family Editing (Family Types)
  • Tag Family Labels
This makes me assume it's possible to do so, but i can't find the button to add a Parameter Service parameter like you would with a shared parameter.
3 ANTWORTEN 3
Nachricht 2 von 4
rabinob19
als Antwort auf: jens.lathouwersMR29R
Hello @jens.lathouwersMR29R ! Thank you for trying out Parameters Service. 'Adding parameters to Labels in Tags' functionality is coming up soon (it is already available in Preview Release) and is not available in Revit 2023.0.2. We are going to update the documentation. Also, I would love to hear your feedback on the Parameters Service. Please reach out to boris.rabinovich@autodesk.com, if you would like to discuss the current state and the future of this...
Nachricht 3 von 4
als Antwort auf: rabinob19
Thanks for your reply. Looking forwards to testing this with the Tag label being available as wel.
Looks like a very promising feature.
Nachricht 4 von 4
luisPDAN6
Just upgrade your Revit 2023 to the latest build available. I had some problems with labels, and after the upgrade the parameters showed correctly in the family editor. BTW am using this step-by-step tutorial for the parameter service inside Revit.
