Does anyone know how I can replicate this roof? It has an inclination on one side and the bottom layer is tapered. On one end the roof thickness is 630mm and on the other end it is 500mm. (The current roof is an IFC-link).
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Shape Edit a Variable Thickness Roof using Modify Sub Elements tools.
...based on what I see in your screenshot, I would probably model it as a Extruded Profile Roof in Elevation/Section View. and then cut the geometry to shape in Plan View with an In-Place Void. Might be easier. Definitely faster.
