Me again!
Trying to create a tapered roof insulation.
Checked variable in build-up dialog. I just don't seem to have that additional box to the right of edit parameter which allows you to add points/heights.
Is this REVIT LT limitation? If so, need a work around.
@stuart wrote:I just don't seem to have that additional box to the right of edit parameter which allows you to add points/heights.
Are you talking about Shape Editing tools?
...Variable Thickness doesn't work that way. Read this:
I've done all that and the shape editing tool does not appear still.
I am reading old 2014 posts saying REVIT LT does not have them.
