Tags sometimes don't print to pdf
8 ANTWORTEN 8
Nachricht 1 von 9
pieter1
3247 Aufrufe, 8 Antworten
I have a strange thing going on. I have a lot of wall tags in a particular sheet. Sometimes when I plot the sheet to pdf only half of the tags appear. Then when I try a second or third time (without making any changes to the file) they do appear in the pdf.
Anyone seen this issue before. I searched the forum and google couldn't find any solutions.
I'm using cutepdf but have tested other pdf printers I tested seem to produce the same behaviour.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: pieter1
We are having the same issue. Both wall tags, and even some RLs.
We worked out if you print to PDF using "Current View Only" then they appear. But when you print selected sheets they do print.
Same solution also applies to Spot Elevations, and to Keynotes.
VERY ANNOYING. A bug that will need fixing ASAP
Nachricht 3 von 9
pieter1
als Antwort auf: Anonymous
Service pack 1 is out today. I found out this in the release notes:
Corrects an issue causing some wall tags and duct tags to not print during batch plot.*
Hope this fixes it.
Nachricht 4 von 9
Giosue.Garita
Hi Pieter,
My name is Giosuè, I am a Revit specialist.
I wanted to follow up to see if the Service Pack 1 has solved the problem. If it has not, please let us know and we will be happy to further troubleshoot your issue.
I look forward to hearing from you soon,
Giosuè Garita
Architecture Department
Autodesk Revit Support Team
Cordiali saluti / Kind regards
Giosuè Garita
Autodesk, Inc.
Nachricht 5 von 9
pieter1
als Antwort auf: Giosue.Garita
As far as I can tell this issue is fixed. Thank you for the follow up.
Nachricht 6 von 9
Giosue.Garita
Hi Pieter,
Thank you for the update.
I am happy to hear the problem has been fixed.
Don't hesitate to contact us back if you have further questions or issues with the product; we are always happy to help.
Kind regards,
Giosuè Garita
Giosuè Garita
Autodesk, Inc.
Nachricht 7 von 9
Do i have to download and install the service pack for this bug to be fixed? I am currently using Revit 2017.
Nachricht 8 von 9
steventurkel
Having the same problem, with Revit 2017. How do I check to see what I need to fix this?
Nachricht 9 von 9
als Antwort auf: steventurkel
The only fix we came up with was to have all the sheets opened while plotting or printing . Supposedly this issue has been fixed in the upcoming updates .
